17 years agoerrors in quartus when simulation
I have some code about LEDs cycle. I wrote two process, one is a time divider, the other is LED turn on according with divider. the project was complied, but quartus has some errors when staring simu...
16 years agoIt isn't clear for me yet, i don't understand what is the differnce between to 'in' type either it is clk or inc, inc signal is high for just one clk cycle , and a process runs just when some changes accures in its sensitive list and in my code on just pos edge, exactly what we want to do when we use clk .
i think it should make a D flip-flop for that part that just works on pos edge on inc ( we can consider it as a clk). p.s: but i added a clk signal to my sensitive list to see am i right or not, and put the whole process in a if clause to run just when the clk has changes to high(red part) this is the whole code.. library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.math_real; use ieee.std_logic_unsigned.all; entity dataPath is port(clk, reset, shift, add, inc, swap, comp:in std_logic; datain:in std_logic_vector(15 downto 0); dataout: out std_logic_vector(15 downto 0)); end dataPath; architecture computer of dataPath is signal accumulator:std_logic_vector(15 downto 0):= "0000000000000000"; begin dataout <= accumulator; process(clk, reset, shift, add, inc, swap, comp) begin if ( clk = '1') then if (reset = '1') then accumulator <= "0000000000000000"; else if (shift = '1') then accumulator <= '0' & accumulator(15 downto 1); else if (add = '1') then accumulator <= accumulator + datain; else if (inc = '1' ) then accumulator <= accumulator + 1; else if( swap = '1') then accumulator <= accumulator ( 7 downto 0) & accumulator( 15 downto 8); else accumulator <= accumulator; end if; end if; end if; end if; end if; end if; end process; end computer; --------------------------------------- library ieee; use ieee.std_logic_1164.all; entity controller is port(serialin, clk:in std_logic; reset, shift, add, inc, swap, comp: out std_logic); end controller; architecture ctr_states of controller is TYPE state is ( dummy, dummy1, dummy2, ready, ready1,ready2, ready3, ready4, ready5 , resetS, shiftS, addS, incS, swapS, compS); signal dummy_state, ready_state:std_logic; signal present_state:state:= dummy;signal next_state : state; begin --shayad bayad hazf she -- shift <= '0'; -- add <= '0'; -- inc <= '0'; -- swap <= '0'; -- comp <= '0'; PROCESS(clk) BEGIN if ((clk'EVENT) AND (clk = '1')) then present_state <= next_state; end if; END PROCESS; process( present_state, serialin ) begin case present_state is when dummy => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= dummy1; else next_state <= dummy; end if; when dummy1 => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= dummy2; else next_state <= dummy; end if; when dummy2 => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= ready; else next_state <= dummy; end if; when ready => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= ready3; else next_state <= ready1; end if; when ready1 => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= ready4; else next_state <= ready2; end if; when ready2 => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= shiftS; else next_state <= resetS; end if; when ready3 => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= ready; else next_state <= ready5; end if; when ready4 => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= incS; else next_state <= addS; end if; when ready5 => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= compS; else next_state <= swapS; end if; when resetS => reset <= '1'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= dummy1; else next_state <= dummy; end if; when shiftS => reset <= '0'; shift <= '1'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= dummy1; else next_state <= dummy; end if; when addS => reset <= '0'; shift <= '0'; add <= '1'; inc <= '0'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= dummy1; else next_state <= dummy; end if; when incS => reset <= '0'; shift <= '0'; add <= '0'; inc <= '1'; swap <= '0'; comp <= '0'; if (serialin = '1') then next_state <= dummy1; else next_state <= dummy; end if; when swapS => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '1'; comp <= '0'; if (serialin = '1') then next_state <= dummy1; else next_state <= dummy; end if; when compS => reset <= '0'; shift <= '0'; add <= '0'; inc <= '0'; swap <= '0'; comp <= '1'; if (serialin = '1') then next_state <= dummy1; else next_state <= dummy; end if; -- when others => -- reset <= '0'; -- shift <= '0'; -- add <= '0'; -- inc <= '0'; -- swap <= '0'; -- comp <= '0'; -- next_state <= dummy; end case; end process; end ctr_states;
