17 years agoerrors in quartus when simulation
I have some code about LEDs cycle. I wrote two process, one is a time divider, the other is LED turn on according with divider. the project was complied, but quartus has some errors when staring simu...
17 years agoHi,
I don't quite follow you about ASIC, I wouldn't bother about that if I am doing FPGAs. If you are just testing leds with datan values then you get the test pattern(you only need clock and reset inputs) Your code can be like this if you want safe design: process(reset,clk) begin if (reset='0') then ledn <= (others => '0'); datan <= (others => '0'); counter<=(others=>'0'); elsif (clk'event and clk='1') then count <=count + 1; -- assuming modulo 2, no maximum defined if(count(10) = '1')then -- divider datan <= datan + 1; end if; case datan is when "000" => ledn<="10000000"; when "001" => ledn<="00000001"; when "010" => ledn<="00000010"; when "011" => ledn<="00000100"; when "100" => ledn<="00001000"; when "101" => ledn<="00010000"; when "110" => ledn<="00100000"; when "111" => ledn<="01000000"; end case; end if; end process; Notice that leds wouldn't show to the eye when fast changes occur. So you should be kind to the eye limitations. There will also be one clock latency in simulation between datan value and ledn value
