9 years agoError when using University Program VwF
I'm using Quartus 16.1 I want to simulate, but when I press Run functional simulation this error occur " Warning (18236): Number of processors has not been specified which may cause overloa...
OBon0
6 years agoI also had this problem and it looks like I found an easy workaround:
a) Remove bad wave form file;
b) Clean and rebuild project
c) Create new Waveform.vwf but save it in the project root (not output_files).
d)Press "Generate Modelsim..."
For some reason in my case the vwf file was created in output_files until I forced it to be at the right place. And I also followed the advice to declare path to ModelSim
