9 years agoError when using University Program VwF
I'm using Quartus 16.1 I want to simulate, but when I press Run functional simulation this error occur " Warning (18236): Number of processors has not been specified which may cause overloa...
9 years agoHi, i´m starting with Quartus and find the same problem. The "solution" that i´ve found is not change the name of the .vwf file. When the name is the default one, "waveform.vwf", I have no problem. If I change it, i got trouble.
