14 years ago
Error when starting SignalTap from MATLAB
The code:
addpath(genpath('C:\altera\11.1\quartus\bin64'));
alt_signaltap_run
Error appear when run alt_signaltap_run. At next, Matlab crashes.
Q11.1sp2, Matlab 7.12.0 (R2011A), Win7x64 installed.
Microsoft Visual C++ Runtime Library
Assertion failed!
Program: ...
File: d:/SJ/nightly/11.1/173/w64/p4/qu.../mex_si...ain.cpp
Line: 142
Expression: ver_handle
For information on how your program can cause an assertion
failure, see the Visual C++ documentation on asserts
(Press Retry to debug the application - JIT must be enabled)
Abort    Retry   Skip
Why? How to fix it?
    You need to add the Quartus bin directory to your system path.
    You can either do this by right-clicking on My Computer and selecting Properties, Advanced and then Environment Variables. Then modify the variable PATH to add C:\altera\11.1\quartus\bin64; to the beginning.
    Alternatively type the following in MATLAB first:
    setenv('path', ['C:\altera\11.1\quartus\bin64;' getenv('path')])
