14 years agoError when starting SignalTap from MATLAB
The code:
addpath(genpath('C:\altera\11.1\quartus\bin64'));
alt_signaltap_run
Error appear when run alt_signaltap_run. At next, Matlab crashes. Q11.1sp2, Matlab 7.12.0 (R2011A), Win7x...
13 years ago --- Quote Start --- Hi,i have the same problem,can anyone help me to resolve this problem,thanks! code : Microsoft Visual C++ Runtime Library --------------------------- Assertion failed! Program: ... File: d:/SJ/nightly/11.1/173/w64/p4/qu.../mex_si...ain.cpp Line: 142 Expression: mat_handle For information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts (Press Retry to debug the application - JIT must be enabled) --------------------------- Abort Retry Skip --------------------------- --- Quote End --- The Altera Support person told me it is bug in the MATLAB and might be fixed in coming days. Until then you can open the project in Quaturs and use the same signal tap file directly. Hope this helps..
BazingaWei
6 years agoi have the same problem, have you solved it? I'm using Quartus II 14.1 and Matlab 2016b.
Best Regards
