10 years agoError using while converting code to VHDL
Dear All, I am trying to find delay between two signals using cross correlation on FPGA .Kindly can some one please help me how i can do that. Any link or any useful informati...
10 years ago --- Quote Start --- I cannot open the file because I don't have the software, but I assume the names are all correct. If you have code, could you post that in a post instead of an attachment? What is connected to output port 1? Is this an array with a single element? --- Quote End --- @Pietr.Thanks for your reply.I have written the code in my post. In figure there are 4 blocka two i/n and one o/p block. The code above is written in function block the middle one.Can you check it please. here is code x1=[1 2 3 4 5 6 7 8 9]; x2=[3 4 5 6 7 8 9 2 1]; n=length(x1); xc=zeros(2*n-1,1); for i=1:2*n-1 if(i>n) j1=1; k1=2*n-i; j2=i-n+1; k2=n; else j1=n-i+1; k1=n; j2=1; k2=i; end xc(i)=sum(conj(x1(j1:k1)).*x2(j2:k2)); end xc=flipud(xc);
