13 years agoError: Selected device has 105 RAM location
Hello
when I was in the process of compiling my program I got this errorError: Selected device has 105 RAM location(s) of type M4K. However, the current design needs more than 105 to successfully fit Any one can help me plz7 Replies
thank you problem solved, I changed the device
Find out which SOPC components is using RAM blocks in your system and reduce their sizes.
hello
I am a beginner in this field, is that you can tell me how to REDUCE the number of RAM plz - Altera_Forum
ok thank you :)
SOPC won't give an error. The fitter would give an error after failing to fit the design in the fpga.
thank you for reponce
but already I compile an IP knowing his SOPC Builder system is ready - Altera_Forum
You are using more ram in your design than the amount that can fit in the device..
Reduce the ram. - Zubair
