16 years agoError: Peak virtual memory: 255 megabytes
Hello, I'm new to FPGA. I'm doing this for a 4th year course and I'm facing a problem. When I compile the project, I'm getting these errors:
Error: Design contains 10582 blocks of typ...
16 years ago --- Quote Start --- I didn't do anything special. For some reason I can't open the project in 9.0 without Quartus crashing. Please do something for me: 1 - Open the compilation report for your project. 2 - Expand the "Analysis & Synthesis" section of the report. 3 - Click on the "IP Cores Summary" report. This will give you a list of the IP used in the project along with it's corresponding license. If any of those IP cores have an OpenCore evaluation license, your design will consume more logic when you build it than when I build it. Jake --- Quote End --- Hi Jake, thanks for your info. I did not get the "IP Cores Summary", but the warning during Analysis & Synthesis that the NIOS II will use the Evaluation feature. I never get the information that the synthesis results of an evaluation version will be worse than the licenced version. Kind regards GPK
