16 years agoError: Peak virtual memory: 255 megabytes
Hello, I'm new to FPGA. I'm doing this for a 4th year course and I'm facing a problem. When I compile the project, I'm getting these errors:
Error: Design contains 10582 blocks of typ...
16 years ago --- Quote Start --- Hi, I have a good and a bad message for you. The good one I could run your project , but it doesn't fit. I will have a brief look to it. Kind regards GPK --- Quote End --- Hi, the bad news is that your design needs 12302 logic elements. I got this number by running your design with a larger device selected. The number of the logic elements you got with the error message is not correct ( I never trust this numbers in the past). Your device has only 10xxx logic elements. I'm pretty sure that you will not get a fit without modifying ( means reduce your design size) your design. Even the best area optimization algorithm will not bring down your design to the required size. Sorry for this bad news. Kind regards GPK
