15 years ago
Error: Node instance "U1" instantiates undefined entity
I have a verilog code working with multiple files. I use synopsys library DW01_addsub, DW02_mult, DW01_add, DW01_sub and DW03_pipe_reg so that the resource can be optimal.
When I tried to start Alalysis & Elaboration (Quartus II version 10.1), there are many errors:
Error: Node instance "U1" instantiates undefined entity "DW01_addsub"
Error: Node instance "mult" instantiates undefined entity "DW02_mult"
Error: Node instance "add" instantiates undefined entity "DW01_add"
Error: Node instance "sub" instantiates undefined entity "DW01_sub"
Error: Node instance "U1" instantiates undefined entity "DW03_pipe_reg"
I think there might be because of no link (path) to the synopsys library DW, is it right?
How to link with the synopsys library?
    I provide this path "c:/altera/10.1/quartus/eda/synopsys/dw/lib" in both Global Libraries and Project Libraries. It is still show the errors.
    Did I provide the right path? or any other ideas?
    Yes that the problem. If you have the verilog/vhdl source for the library elements you add them through assignment->settings->Libraries
    Pete
