15 years agoError: Node instance "U1" instantiates undefined entity
I have a verilog code working with multiple files. I use synopsys library DW01_addsub, DW02_mult, DW01_add, DW01_sub and DW03_pipe_reg so that the resource can be optimal. When I tried to start...
15 years agoYes that the problem. If you have the verilog/vhdl source for the library elements you add them through assignment->settings->Libraries
Pete
