ABola2
7 years agoError: Makefile is not up to date @ NIOS 2 Eclipse
Again and again I see this error every time I edit the BSP settings: make all Makefile not up to date. settings.bsp has been modified since the BSP Makefile was generated. Generate the BSP to upd...
- 7 years agoHi, Sometimes the compiler isn't able to update the Makefile and when you update the BSP settings the Makefile will be out of date: To work around this, do the following: 1- Open the BSP project folder 2- Right click the Makefile>> Delete 3- Open the NIOS II Command Shill 4- Write the following command: cd <...../project_bsp> nios2-bsp-generate-files --settings=settings.bsp --bsp-dir=<C:/…./<project_bsp/> 5- Build your project again. I've tried this and the issue gone.
ABola2
7 years agoThanks a lot, It is amazing solution for now. do you know when you gunna fix this issue completely?
