ABola2
7 years agoError: Makefile is not up to date @ NIOS 2 Eclipse
Again and again I see this error every time I edit the BSP settings: make all Makefile not up to date. settings.bsp has been modified since the BSP Makefile was generated. Generate the BSP to upd...
- 7 years agoHi, Sometimes the compiler isn't able to update the Makefile and when you update the BSP settings the Makefile will be out of date: To work around this, do the following: 1- Open the BSP project folder 2- Right click the Makefile>> Delete 3- Open the NIOS II Command Shill 4- Write the following command: cd <...../project_bsp> nios2-bsp-generate-files --settings=settings.bsp --bsp-dir=<C:/…./<project_bsp/> 5- Build your project again. I've tried this and the issue gone.
Abe
7 years agoIf the above steps do not resolve the issue, do a make clean or make clean_bsp and then delete the Makefile that is present in the BSP directory as well as in the Application directory. After doing this, you will have to generate the Makefiles again and then do the BSP & APP builds.
