17 years agoerror in compiling VHDL CODE
sir, i'm using modelsim for simulating my VHDL code. When i was simulating, i encountered an error. The error statement was as given below: Signal "prior_a0" is type ieee.std_logic_1164.std_logi...
17 years agohey varun first define this signal, lead_user_output;
(I could not found this in ur code) And also take care of its size, U should assign this signal to a signal of same size only...........
