17 years agoerror in compiling VHDL CODE
sir, i'm using modelsim for simulating my VHDL code. When i was simulating, i encountered an error. The error statement was as given below: Signal "prior_a0" is type ieee.std_logic_1164.std_logi...
17 years agoHey Varun...I m trying to give u the solution....
This is the part of ur code U had send me....... --------------------------------------------------- component lead_user port(c: in std_logic_vector(3 downto 0); a0: in std_logic_vector(8 : 4); a1: in std_logic_vector(8 : 4); a2: in std_logic_vector(8 : 4); a3: in std_logic_vector(8 : 4); e: in std_logic; s: in std_logic; reset: in std_logic; x: out std_logic_vector(1 downto 0)); end component; --------------------------------------------------------- and this is the line of code where u r mapping the port.... -------------------------------------------------------- lead : lead_user port map(prior_a0,prior_a1,prior_a2,prior_a3, prior_e,prior_s,lead_user_c,lead_user_output); ------------------------------------------------ Here u r using positional mapping of ports......... So, prior_a0 will be assigned to C, prior_a1 will be assigned to a0, prior_a2 will be assigned to a1, prior_a3 will be assigned to a2, and so forth...... I hope u got this point........ And The prior_a0 which is a single bit value which is assigned to a0: in std_logic_vector(8 : 4); a multi bit value.......... So after proper mapping of ports....u should match the type of ports also
