17 years agoerror in compiling VHDL CODE
sir, i'm using modelsim for simulating my VHDL code. When i was simulating, i encountered an error. The error statement was as given below: Signal "prior_a0" is type ieee.std_logic_1164.std_logi...
17 years agoHi,
--- Quote Start --- lead : lead_user port map(prior_a0,prior_a1,prior_a2,prior_a3, prior_e,prior_s,lead_user_c,lead_user_output); You are mapping ports by position, and not by name. here prior_a0 is mapped to port c on lead_user component which have different types. I suggest you to employ port mapping by name like --- Quote Start --- lead : lead_user port map( c => ...,a0 => ... ,a1 => .... ...); --- Quote End --- I think, you are confused about what you want exactly to do. You want to connect a single signal to a "composed" signal. Are you sure about your design ? It's very important. vhdl just describes a logical circuit.
