14 years agoERROR in Character LCD Cyclone III dev kit
I have a SOPC set up with a CPU Processor, On-Chip memory, JTAG UART, and Character LCD. The clock is 50 Mhz.
LCD_E_from_the_lcd_0 --> lcd_en [PIN_AC24] (set OUTPUT) LCD_RS_from_the_lcd_0 --> lcd_d_cn [PIN_D27] (set OUTPUT) LCD_RW_from_the_lcd_0 --> lcd_wen [PIN_AC4] (set OUTPUT) LCD_data --> lcd_data[7..0] (set INOUT) I do NOT have "Reduced device drivers" checked, because the LCD drivers do not provide small drivers. My code in NIOS II is : #include <stdio.h> #include <system.h> #define ESC_TOP_LEFT "[1;0H" #define ESC_BOTTOM_LEFT "[2;0H" #define LCD_CLR "[2J" #define LCD_CLR_LINE "[K" static unsignedchar ESC = 0x1b; void lcd_hello(void) { FILE* LCD; LCD = fopen (LCD_0_NAME, "w"); if(LCD == NULL) { printf("LCD open failed\n"); } else { printf("LCD open succeeded\n"); fprintf(LCD, "%c%s", ESC, LCD_CLR); // Clears LCD fprintf(LCD, "LCD demo using\n"); fprintf(LCD, "altera HAL in C"); } fclose(LCD); } int main (void){ LCD_hello(); while(1); return 0; } Is my code wrong? My kit (LCD) does't work. Thank uNo RepliesBe the first to reply
