13 years agoError: CONF_DONE failed to go high in device 1.
Before anyone comments on this, I have searched the forum and read everything I have found on the internet with people getting this error message. :) I'll try to post as much relevant information ...
13 years ago --- Quote Start --- Ok. So you can auto-detect your FPGA, CONF_DONE toggless and pll voltage is ok. Can you now check fpga supply voltages with oscilloscope at the rising edge of conf_done? --- Quote End --- No, CONF_DONE never toggles. It just stays low from start up. I have checked the supply voltages to verify that they don't dip or anything like that. So that part should be OK. Edit: According to this app note it would seem that the FPGA is in Configuration Mode. I don't know if that has any implications though.. http://www.altera.com/literature/hb/cfg/cfg_cf51001.pdf
