13 years agoError: CONF_DONE failed to go high in device 1.
Before anyone comments on this, I have searched the forum and read everything I have found on the internet with people getting this error message. :) I'll try to post as much relevant information ...
13 years agoThings I have noticed:
1. DEV_OE and INIT_DONE are each connected to a LED to ground with 470ohm resistors. They light up for a moment when I click the program-button in the Device Programmer. They both give 3,3V. - When INIT_DONE lights up, this should mean that the FPGA has entered "User Mode". But what does it mean when it goes high for a moment and then low again? Might this be the registers initializing to a high value or something like that before configuration? More things I have tried: 2. Checking the box for Compressed Bitstream. No effect. 3. Enabling device-wide output enable (DEV_OE) and reset (DEV_CLRn) as per suggestions in another thread. No effect. 4. Disconnecting the LEDs on DEV_OE and INIT_DONE, suspecting they'd overload the output. No effect.
