10 years agoError Code: *** Fatal Error: Int Divide By Zero Module: quartus_map.exe Stack Trace:
*** Fatal Error: Int Divide By Zero Module: quartus_map.exe Stack Trace: 0x258e4: GEN_MACHINE_INFO::get_cache_size + 0x3b4 (CCL_GEN) End-trace I continue to get this error...
10 years agoYes, Galfonz is right. Quartus II internal error cannot be fixed by user. You need to file case to MySupport and get a patch to workaround it.
