Blues-sptn
5 years agoError (209034): Can't find JTAG Server
I am using a Stratix V device. I am currently evaluating Stratix V. When I try to write SOF using 18.1 Programmer on a Windows 10 PC When I try to write SOF, I get the following error message When...
- 5 years ago
Yes, this KDB is applicable.
At the meantime, i would suggest to reinstall the USB driver in windows 10 to solve the problem. Below are the steps that you can refer to:
- Plug the USB-Blaster into your PC.
- Open the Device and Printers (Control Panel | Devices and Printers).
- Under Unspecified, USB Blaster should be listed. Right mouse click on this and then select Properties.
- Select the Hardware tab and select Properties.
- A new window should pop up with the General tab already selected. Select Change Settings.
- Again a new window should pop up with the General tab already selected. Select Update.
- Select Browse my computer for driver software.
- Find <Path to Quartus II installation>\quartus\drivers\
- (Note 1: Your altera file is located at the location you selected when you first installed quartus. The location listed in this document is the default location)
- (Note 2: Stop at the drivers folder, i.e., do NOT go deeper by opening a folder within the drivers folder)
- Select OK. Make sure the proper path was selected then select Next.
- If the Windows security window pops up Check the Always trust software from “Altera Corporation”box and select Install.
YuanLi_S_Intel
5 years agoYes, this KDB is applicable.
Blues-sptn
5 years agoThanks for the reply.
It worked fine with the ver13.1 driver.
