11 years agoError (209025): Can't recognize silicon ID for device 1; Cyclone IV Issue
I've got my brand new, custom, Cyclone IV hardware up and running and am running into problems using .jic programming. My configuration device is a Micron M25P80, I chose it because I've used it in ...
11 years agoMy apologies. I've come to discover the board was actually loaded with a Macronix "substitute", the MX25V8006E. Even so, it appears (from the datasheet) to be functionally compatible with the M25P80 except for a different mfg ID. Shouldn't the "disable EPCS ID check" allow the use of this part?
