AlexBarry
2 years agoError 169182 with Cyclone 10 LP
I am compiling a design for the Cylcone 10 LP (10CL025YE144I7G). We use using active serial configuration mode. Currently, we have a 3.3V LVCMOS output signal on pin 11. When I added the serial fl...
- 2 years ago
why do you need SFL integrated with application code. Standard solution would be default SFL image loaded by programmer, it doesn't conflict with any application pin assignments.
FvM
2 years agoHi,
