Error (16021) using 10M08SCE144C8G
Per our observation based on the compilation report, the error occur when using 10M08SCE144C8G is because the device does not support your design.
As you can see from the compilation report, the design has used all the Embedded Multiplier 9-bit elements 48 / 48 ( 100 % ), which is not enough for 10M08SC as the design need more hence it overused the Total logic elements 11,504 / 8,064 ( 143 % ) - , thus compilation is failed.
Family MAX 10
Device 10M08SCE144C8G
Timing Models Final
Total registers 1196
Total pins 32 / 101 ( 32 % )
Total virtual pins 0
Total memory bits 0 / 387,072 ( 0 % )
Total PLLs 0 / 1 ( 0 % )
UFM blocks 0 / 1 ( 0 % )
ADC blocks 0
Your design need to use bigger device which is 10M16SCE144C8G that is suitable with your design.
Family MAX 10
Device 10M16SCE144C8G
Timing Models Final
Total logic elements 7,786 / 15,840 ( 49 % )
Total registers 1088
Total memory bits 0 / 562,176 ( 0 % )
Embedded Multiplier 9-bit elements 90 / 90 ( 100 % )
ADC blocks 0
Aiman
- alex1002 years ago
Appreciate all the replies. I believe I've found the answer.
