alex100
2 years agoError (16021) using 10M08SCE144C8G
I'm utilizing the MAX10 FPGA, specifically the 10M08SCE144C8G model, to generate sweeping sinewave signals using lookup tables and multipliers. However, during compilation, I encountered the followin...
Farabi_Altera
2 years agoHi Alex, Do you have updates from previous request?
regards,
Farabi
alex100
2 years agoUsing 10M016SCE144C8G and Single Uncompressed Image (256Kbits UFM) was successful. Need 7807 logic elements.
Using 10M08SCE144C8G and Single Uncompressed Image (256Kbits UFM) was unsuccessful. Need 11,504 logic elements.
This is the flow Summary (using 10M08SCE144C8G) after compiling:
Flow Status Flow Failed - Thu Feb 15 11:01:02 2024
Quartus Prime Version 21.1.1 Build 850 06/23/2022 SJ Lite Edition
Revision Name Ramp50M
Top-level Entity Name Ramp50M
Family MAX 10
Device 10M08SCE144C8G
Timing Models Final
Total logic elements 11,504 / 8,064 ( 143 % )
Total registers 1196
Total pins 32 / 101 ( 32 % )
Total virtual pins 0
Total memory bits 0 / 387,072 ( 0 % )
Embedded Multiplier 9-bit elements 48 / 48 ( 100 % )
Total PLLs 0 / 1 ( 0 % )
UFM blocks 0 / 1 ( 0 % )
ADC blocks 0
The report during compilation is attached.
