alex100
2 years agoError (16021) using 10M08SCE144C8G
I'm utilizing the MAX10 FPGA, specifically the 10M08SCE144C8G model, to generate sweeping sinewave signals using lookup tables and multipliers. However, during compilation, I encountered the followin...
Farabi_Altera
2 years agoHi Alex, Do you have updates from previous request?
regards,
Farabi
- alex1002 years ago
Using 10M016SCE144C8G and Single Uncompressed Image (256Kbits UFM) was successful. Need 7807 logic elements.Using 10M08SCE144C8G and Single Uncompressed Image (256Kbits UFM) was unsuccessful. Need 11,504 logic elements.This is the flow Summary (using 10M08SCE144C8G) after compiling:"-----------------------------------Flow Status Flow Failed - Thu Feb 15 11:01:02 2024Quartus Prime Version 21.1.1 Build 850 06/23/2022 SJ Lite EditionRevision Name Ramp50MTop-level Entity Name Ramp50MFamily MAX 10Device 10M08SCE144C8GTiming Models FinalTotal logic elements 11,504 / 8,064 ( 143 % )Total registers 1196Total pins 32 / 101 ( 32 % )Total virtual pins 0Total memory bits 0 / 387,072 ( 0 % )Embedded Multiplier 9-bit elements 48 / 48 ( 100 % )Total PLLs 0 / 1 ( 0 % )UFM blocks 0 / 1 ( 0 % )ADC blocks 0-------------------------------------"The report during compilation is attached.
