Error (16021) using 10M08SCE144C8G
Dear FvM,
I would like to express my gratitude for addressing my queries.
1) Compilation Results:
I performed compilations with both 10M16SCE and 10M08SCE devices, yielding notable differences in outcomes.
For the 10M16SCE144C8G device, the compilation using Single Uncompressed Image (256Kbits UFM) was successful, as evidenced by the following details:
Flow Status Successful - Thu Jan 25 17:47:39 2024
Quartus Prime Version 21.1.1 Build 850 06/23/2022 SJ Lite Edition
Revision Name Ramp50M
Top-level Entity Name Ramp50M
Family MAX 10
Device 10M16SCE144C8G
Timing Models Final
Total logic elements 7,807 / 15,840 ( 49 % )
Total registers 1088
Total pins 32 / 101 ( 32 % )
Total virtual pins 0
Total memory bits 0 / 562,176 ( 0 % )
Embedded Multiplier 9-bit elements 90 / 90 ( 100 % )
However, reverting to the 10M08SCE144C8G device (with Single Uncompressed Image (256Kbits UFM)) resulted in a failure, requiring 11,504 logic elements, exceeding the device's capacity:
Flow Status Flow Failed - Fri Jan 26 11:27:49 2024
Family MAX 10
Device 10M08SCE144C8G
Timing Models Final
Total logic elements 11,504 / 8,064 ( 143 % )
Total registers 1196
Total memory bits 0 / 387,072 ( 0 % )
Embedded Multiplier 9-bit elements 48 / 48 ( 100 % )
Furthermore, attempting to compile with "Single Compressed Image (720Kbits UFM)" on the 10M08SCE144C8G device also failed, displaying Error 16021. The details are as follows:
2) .qsf File Modification:
As you pointed out, there is a line in the .qsf file that reads "set_global_assignment -name INTERNAL_FLASH_UPDATE_MODE "SINGLE IMAGE." What steps should I take about this line?
3) Workaround Implementation:
This link
https://www.intel.com/content/www/us/en/support/programmable/articles/000074796.html?erpm_id=6573007_ts1706295120833
suggested a workaround:
Resolution
Signal declaration for memory_type should be changed from
signal mem : memory_type :=(others => (others => '0'));
to
signal mem : memory_type;
This is to ensure that memory is not initialized and there is no compilation error in the Assembler stage.
I'm using Verilog language and am not sure how to implement this workaround.
Once again, thank you for your assistance.
