Fouad_Elayyach
2 years agoError (12028): Can't read or find LMF file src/Antenna_Array_uart_tb.lmf
Where can I find an example .lmf file for a MAX 10 Device? or how do I generate such a file from within Quartus Prime (v.18.1)? Thanks for the help everybody!
ShengN_altera
2 years agoHi,
Are you specifying src/Antenna_Array_uart_tb.lmf under Assignments -> Settings -> EDA Tool Settings -> Design Entry/Synthesis? If yes, you can delete that path and the Quartus existed .lmf file will be auto specifying when choosing the Tool name. It'll be the same since src/Antenna_Array_uart_tb.lmf is Intel's auto-generated file as mentioned before, probably just the file name different.
Let me know if you have any further update or concern.
Sheng
