Error (12028): Can't read or find LMF file src/Antenna_Array_uart_tb.lmf
Check this link https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/reference/glossary/def_lmf.htm LMFs for EDIF Input Files and VQM Files are specified as Compiler input files when you specify an LMF in the File name box in the Design Entry & Synthesis page of the Settings dialog box (Assignments menu). LMFs for VHDL Design Files are specified in the VHDL Input page of the Settings dialog box (Assignments menu), and LMFs for Verilog Design Files are specified in the Verilog HDL Input page of the Settings dialog box.
Also check this link https://www.intel.com/content/www/us/en/support/programmable/articles/000078097.html
All the .lmf file can be found in the Quartus installation directory: <Quartus Installation Path>\quartus\lmf.
Is that Antenna_Array_uart_tb.lmf a custom .lmf? May be have to check back that design.
Sheng
Is that Antenna_Array_uart_tb.lmf a custom .lmf? it's intel's file but can't find it in Quartus installation?
