11 years agoError (10481): VHDL Use Clause error at alt_sld_fab_alt_sld_fab_sldfabric.vhd
Hi all, I am trying to use the embedded ADC in Max10 (10M08SAE144C8GES). I have generated the Altera Modular ADC IP Core, the ALTPLL IP Core and the JTAG to Avalon Master Bridge, as suggested in "...
11 years ago --- Quote Start --- Hi all, I am trying to use the embedded ADC in Max10 (10M08SAE144C8GES). I have generated the Altera Modular ADC IP Core, the ALTPLL IP Core and the JTAG to Avalon Master Bridge, as suggested in "MAX10 Analog to Digital Converter User Guide". However, when I synthesize the module I obtain these errors: Error (10481): VHDL Use Clause error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(7): design library "altera_sld" does not contain primary unit "sld_hub_pack" Error (10800): VHDL error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(7): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(8): design library "altera_sld" does not contain primary unit "sld_jtag_hub_pack" Error (10800): VHDL error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(8): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(9): design library "altera_sld" does not contain primary unit "jtag_pack" Error (10800): VHDL error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(9): selected name in use clause is not an expanded name This file vhd is automatically generated by Quartus 15.0 software. I think it is a problem of library. Does someone know how fix this problem? Thank you for your help. --- Quote End --- I ran into this exact same problem and found out why it occurred for me. Perhaps it will help you. My Quartus environment for version 15 is on Windows 10 running under Parallels VM on a Mac. I was running lab 3 from the DECA workshop course put on by Arrow. This lab creates a NIOS II processor and shows off the QSYS, Quartus, and Eclipse tools. All the files were on my Mac desktop and to make the lab easier to find in the file dialogs, I mapped the folder to a drive letter. The first time I compiled I did not see this error but because I had made a naming error in QSYS, I had to go back and rename a module. From then on, I got this error. What eventually cleared the error was to map a drive letter to a folder higher up in the directory structure: So instead of L:\labfolder I did: M:folder1\folder2\labfolder This seemed to fix the problem. I don't know if it will help you in your case but it solved it for me and perhaps there is a bug being exposed by the method I used. Interestingly, 40% of the workshop attendants were using Macs to run Quartus. Not sure if this is saying Mac people would like to develop hardware or hardware people like to use Macs.
