11 years agoError (10481): VHDL Use Clause error at alt_sld_fab_alt_sld_fab_sldfabric.vhd
Hi all, I am trying to use the embedded ADC in Max10 (10M08SAE144C8GES). I have generated the Altera Modular ADC IP Core, the ALTPLL IP Core and the JTAG to Avalon Master Bridge, as suggested in "...
11 years agoHi nic_@,
Actually it is the opposite: the web edition gives the error and the 30-day evaluation Quartus II is ok. Maybe the problem is that with the web edition you don't have some libraries. I have to check if I can copy the library files from the one that works to the other one. Anyway, thank you for your reply.
