14 years agoError (10028): Can't resolve multiple constant drivers for net "FinalHash[63]" at has
can anyone help me with this error? FinalHash[63:0] is only used once in this always block. i can't find any solution with this error.
Thanks, jd4 Replies
--- Quote Start --- so i have to remove it in the sequential logic? --- Quote End --- I didn't check the code details, but you can't reset a signal in the always block that is assigned outside of it. Neither it makes sense. - Altera_Forum
indeed your HashFinal is assigned in both comb logic block and sequential logic block. check again.
Error (10028): Can't resolve multiple constant drivers for net "HashFinal[63]" at hashCalc.v(158)
Error (10029): Constant driver at hashCalc.v(3281) and all the bits in the HashFinal has the same error
