ViniNess
2 years agoEPM3128 5v output
Hi guys, fine? I read on datasheet that the EPM3128 can output 5v, but when i go to pin planner i just can se 2.5v or 3.3v How can i config to 5v output? Thanks
_AK6DN_
2 years agoI have an EPM3064A design that I have in Quartus 13.0sp1 done in verilog, and causing outputs to be detected and used in open collector mode is easy. Here is a snippet of my code where the RED ... GRN LED drivers are detected and setup as open collector.
No other special setup in the .qsf files required, other than assignment to the appropriate pin number and the I/O type to "3.3-V LVTTL".
assign IO_RED = RED ? 1'b0 : 1'bz; assign IO_YEL = YEL ? 1'b0 : 1'bz; assign IO_GRN = GRN ? 1'b0 : 1'bz;
