ViniNess
2 years agoEPM3128 5v output
Hi guys, fine? I read on datasheet that the EPM3128 can output 5v, but when i go to pin planner i just can se 2.5v or 3.3v How can i config to 5v output? Thanks
FvM
2 years agoHi,
did the MultiVolt I/O chapter answer your question?
MAX3000A can't drive higher output voltage than 3.3V VCCIO. It's sufficient high level for 5V TTL but possibley not 5V CMOS which requires e.g. 0.7*5 = 3.5 V minimal Vih. You can configure MAX3000A output as open drain and achieve 5V output with pull-up resistor in this case.
- ViniNess2 years ago
Hi
"did the MultiVolt I/O chapter answer your question?"
Not much, i'm kind confused
So, i want to send a 8-bit dataline to a 5V processor
How can i config those pins to open drain?
The restant of the system is 3.3V- FvM2 years ago
not sure if there's an open drain output option in assignment editor for MAX3000, too many years since I used this device family. Depending on your design entry method, open drain can be setup in HDL or graphic design.
