TomD
5 years agoEPM3032A replacement
I have to replace an EPM3032A in an existing design. It was originally programmed using Quartus II Version 8.0. It is a very simple application using about half the I/O and even less of the functio...
ak6dn
5 years agoThe POF file will not directly work. You will need to recompile the design using the '7032AE as the target to generate a new POF file.
Electrically the parts should be compatible (VccINT, VccIO, etc).
QuartusIIWeb 13.0sp1 is the last version that supports the MAX EPM7000/EPM3000 series parts.
TomD
5 years agoThanks. This is a big help
