EPM3032A replacement
The POF file will not directly work. You will need to recompile the design using the '7032AE as the target to generate a new POF file.
Electrically the parts should be compatible (VccINT, VccIO, etc).
QuartusIIWeb 13.0sp1 is the last version that supports the MAX EPM7000/EPM3000 series parts.
- TomD5 years ago
Thanks. This is a big help
- EngWei_O_Intel5 years ago
Hi Tom
Functionally it should work. You have to check on the power specification and pin connection of both devices for proper design migration.
Please refer to below documents for both Max 3000 and 7000:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ds/m7000a.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ds/m3000a.pdf
Eng Wei
- TomD5 years ago
Thanks, this is also a big help
Hi Tom
Eng Wei
