16 years agoEPM240T100 CPLD Ouput Overvoltage?
I have an dedicated output tied to a shared SPI bus. One of the other bus drivers, drives to 5V. My CPLD is powered by 3.3V. When my CPLD output is not is use, so high impedance, is there a spec o...
16 years agoBy MAX II specification, it's not o.k. to drive 5V to a pin. You need to add a clamp diode. According to the device manual, internal PCI clamping diodes can be enabled for part of the MAX II pins (if I remember right, only with larger packages). But they are not active before user mode starts, so you may want to have a safe hardware clamp instead.
