10 years agoEPM2210 state of I/O pins during configuration time of the CPLD upon power up
Regarding the MAX II CPLD family, the EPM2210 CPLD: At power on during the configuration time of the CPLD, what is the default state of all its I/O pins? From the datasheet, i have read that dur...
10 years agoYou can't change the pull-ups during the download period at power on. Prior to the device being configured all I/O pins will have a weak pull-up enabled.
Once the device has booted with your design you can disable the pull-up. However, you can't add a pull-down internally. As Galfonz says, you'll have to add an external pull-down. Cheers, Alex
