15 years agoEPM1270 i/o problem
I read a CS5532 when EPM1270 found a problem. I give an order of 5532, when the internal logic of concurrent write a command to the SCLK pin on the pin but occasionally did not wave. I count the internal logic of the output and found that the data actually sent me, just do not know why the pin did not respond. So I divided by the system clock connected to the SCLK pin when the pin output is also normal, no-no wave.
I count the SCLK output is normal, and SCLK, and DOUT is simultaneously, or both did not
module _ad_spi(
input wire clk,// input wire rst_n, input wire _init_start, input wire output_enable, input wire output_flag, input wire [7:0] _AD_indata, output reg [23:0] _AD_outdata, output reg _Get_Data_Flag_out, output reg _AD_sclk,//SPI port output reg _AD_sdo, input wire _AD_sdi ); reg [2:0] state; // statemachine state reg [5:0] transmit_count; //transmit count reg [23:0]_AD_data; //temp 24bits data reg _get_data_over; //get data over flag reg [7:0] treg; //transmit reg ///////////////////////////////////////////////////////////////////////////// always @(*)//out put data begin if(!rst_n) _AD_outdata <=0; else if(output_enable&&_get_data_over == 1) _AD_outdata <= _AD_data; end ///////////////////////////////////////////////////////////////////////////// always @(posedge clk or negedge rst_n) if (~rst_n) begin state <= 3'b000; // idle transmit_count <= 6'b000000; treg <=# 1 8'h00; _AD_sclk <= 1'b0; _AD_sdo <= 0; end else begin _Get_Data_Flag_out <= 0; case (state) //synopsys full_case parallel_case 3'b000: // idle state begin transmit_count <= 6'b000000; // set transfer counter treg <= 8'h00; // load transfer register _AD_sclk <= 1'b0; // set sck _AD_sdo <= 1'b0; if(output_flag )//&_init_start) begin treg <= _AD_indata;// load transfer register transmit_count <= 6'h7; // set transfer counter state <= 3'b001; // transfer data state _Get_Data_Flag_out <= 1; _AD_sdo <= _AD_indata[7]; end else if (~_AD_sdi)// & ~_init_start) begin transmit_count <= 6'h28; // set transfer counter state <= 3'b001; // transfer data state _get_data_over <= 0; end end 3'b001: // clock-phase2, next data begin _AD_sclk <= ~_AD_sclk; if(transmit_count == 6'h7) state <= 3'b011; // send data state else if(transmit_count == 6'h28) state <= 3'b101; // recive data state else state <= 3'b000; // idle state end 3'b011: //send data state begin if(~_AD_sclk) begin _AD_sdo <= treg; transmit_count <= transmit_count -6'h1; end if (~|transmit_count) begin state <= 3'b000; _AD_sclk <= 0; _AD_sdo <= 0; end else begin state <= 3'b011; _AD_sclk <= ~_AD_sclk; end end 3'b101: //recive data state begin if(_AD_sclk) begin if(transmit_count >7 && transmit_count < 32) _AD_data <= _AD_sdi; transmit_count <= transmit_count -6'h1; end _AD_sdo <= 0; if (transmit_count == 0 || transmit_count >40) begin state <= 3'b000; _AD_sclk <= 0; if(transmit_count >40) _get_data_over <= 0; else _get_data_over <= 1; end else begin state <= 3'b101; _AD_sclk<= ~_AD_sclk; _get_data_over <= 0; end end default: state <= 3'b000; endcase end endmodule This is my program, you help me see, what is the problem - Altera_Forum
Sounds like a logic design error, e.g. timing related. Without knowing design details and exact observations, we can only guess about it.
