14 years agoEPM CPLD's Internal Osc Frequency
Hi!
I'm working with a EPM570 and need a clock source. I created it with the block ALTUFM_OSC, set the frequency to 5.5 MHz and checked it worked by simulating the circuit. As stated in the help file of ALTUFM_OSC, the frequency of 5.5 MHz I've selected it's only "for simulation purpouses and has no impact on the on-chip oscillator frequency". My question is, what will be the real frequency of the oscillator when I upload the source code to the CPLD? Is it uncertain and will be between 3.3 and 5.5 MHz? If it's really uncertain and I need a deterministic frequency for the global clock, how can I interface a crystal into the CPLDs pins? It may have been asked before, but I had no luck finding the answers. Thanks in advance for your help.3 Replies
Thanks a lot for your help Dave and Tricky!
Didn't know there are crystal oscillators with TTL/CMOS output. Bye! - Altera_Forum
p43 says the real frequency can be between 3.33MHz and 5.56MHz
http://www.altera.com/literature/ug/ug_alt_ufm.pdf Rather than trying to build an oscillator circuit using a crystal, just use an oscillator. http://www.ecliptek.com/ http://www.ecliptek.com/oscillators/ec26/ Route the output of the oscillator to the clock pin of the CPLD. Cheers, Dave - Altera_Forum
The frequency wont be reliable and will vary with temperature. According to the documentation it will only be in the range you specify though.
