14 years agoEPF10k10 reconfiguration
Hi! What's the best way to perform a reset / reconfiguration on the EPF10k10? Looking at the configuration appnote (AN59, page 4) I'm guessing it's as simple as pulling down nConfig which would...
14 years ago --- Quote Start --- I'd have to wrap every block with an if (~reset). No big deal, but still.. --- Quote End --- I'd recommend doing that anyway. When you simulate a design, its nice to use reset to initialize the system - multiple times during the simulation if that is what you are trying to test. If you do not have a reset signal, then you need to initialize all signals, so that the simulation does not start with them all in an unknown state. Anyway, its your call, I just figured I'd point out why you might want to use reset ... Cheers, Dave
