17 years agoEpcs4 interface problem
Hi, I am using EPCS4SI8N through SPI interface to a microcontroller to write and read data. Right now I have done the connections accordingly but have problems with read and write to the serial EE...
17 years ago --- Quote Start --- Hi, By pulling it down u mean...connect a resistor from that line to ground? Thanks! --- Quote End --- yes, if it's a real 1 then you shoudn't have any problem. but if it's Z ( that is shown as 1 ) you will get 0. right?
