17 years agoEpcs4 interface problem
Hi, I am using EPCS4SI8N through SPI interface to a microcontroller to write and read data. Right now I have done the connections accordingly but have problems with read and write to the serial EE...
17 years agoHi,
255 probably means High Impedance. you can check it by pulling it down. are you sure that the IC is properly powered?
