17 years agoEpcs4 interface problem
Hi, I am using EPCS4SI8N through SPI interface to a microcontroller to write and read data. Right now I have done the connections accordingly but have problems with read and write to the serial EE...
17 years agoHi,
so best is realy to start with the indentifier command (0x20). - CS low - write 0x20 - read 3 bytes - CS high I assume you'll get zeros again. If so, you need to check with a scope the right order of the bits, clock edges, etc. Best is to compare it with the drawings e.g. in the data sheet of M25P32. Regards, Heiko
