17 years agoEpcs4 interface problem
Hi, I am using EPCS4SI8N through SPI interface to a microcontroller to write and read data. Right now I have done the connections accordingly but have problems with read and write to the serial EE...
17 years ago> - pull CS low
> - send WREN(0x06) > - pull CS high > - delay(); propose to insert the following lines, to check that the Flash "wants" to talk with you :-) - pull CS low - send RDSR (0x05) - read 1 byte --> shout be 0x02 (=Write Enable Latch is set) - pull CS high Regards, Heiko
