17 years agoEpcs4 interface problem
Hi, I am using EPCS4SI8N through SPI interface to a microcontroller to write and read data. Right now I have done the connections accordingly but have problems with read and write to the serial EE...
17 years agoHi,
Yeah the hold pin is high connected to 3.3V. I think my SPI protocol is correct since it worked fine with SD card. I have done the following steps: - pull CS low - send WREN(0x06) - pull CS high - delay(); - pull CS low -send WRITE(0x02) - send address 1st byte (MSB) - send address 2nd byte - send address 3rd byte (LSB) - send data - pull CS high - delay(); Even for read its done in a similar way but using read opcodes. Thanks!
