16 years agoEPCS4 data format?
I have an EPCS4 on a board with a Cyclone II. I'm using the pof file to load the EPCS4 and that all works fine. I have a processor on the board which then goes to read the EPCS4 to save it on an SD C...
16 years agoThanks, it was far more efficient to use the forum than to go rooting around in the pdf jungle not knowing where to look for what I needed.
So far I have: Write Enable, Write Disable, Read Status, Read bytes, and Read Silicon Id working. I have no doubt the the remaining 5 commands will be working today and I'll be off to other things. Thanks again for you help.
