16 years agoEPCS4 data format?
I have an EPCS4 on a board with a Cyclone II. I'm using the pof file to load the EPCS4 and that all works fine. I have a processor on the board which then goes to read the EPCS4 to save it on an SD C...
16 years agoSounds correct. You need a standard SPI bit order, when sending the serial flash commands and addresses and an inverted (LSB first) bit order when writing or reading the configuration data from/to a file.
