16 years agoEPCS4 data format?
I have an EPCS4 on a board with a Cyclone II. I'm using the pof file to load the EPCS4 and that all works fine. I have a processor on the board which then goes to read the EPCS4 to save it on an SD C...
16 years agoNo need to consult th SRunner software. I've encountered this situation before, but I just could not put my finger on the definitive statement.
Thanks for clearing that up. To sumarize:- In writing from a file (pof or hexout) to an EPCS4 I should send the data from the file to the EPCS4 LSB first.
- In reading data from the EPCS4 I will receive it LSB first assuming it was written according to item 1 above. To rewite this data to a standard file (pof or hexout) I will need to either reverse the bits if shifting from right to left, or equivalently shift them from left to right during byte assembly.
